TwinTurbo.NET: Nissan 300ZX forum - What was the compressionnr`s?
kickerzx
on May 15, 2011 at 6:18 PM
#6 cyl not firing ONLY on idle
posted by BOOZTD 3
on May 15, 2011 at 05:13 PM
Sounds like #6 is slightly low to me
BOOZTD 3
17:13:43 05/15/11
What was the compressionnr`s? -
kickerzx
18:18:01 05/15/11
you've swapped coils and injectors
CGDriven
19:00:28 05/15/11
yes i swapped in a good plug as well... (n/m)
BOOZTD 3
23:25:11 05/15/11
Is there spark? Could be a bad wire going to
EricTTZ
14:34:28 05/16/11
SOLVED: Its compression (or lack of)
BOOZTD 3
18:39:13 05/16/11
did you try squirting a little oil into the cylinder...
CGDriven
19:10:37 05/16/11
THE CULPRIT: Pic inside
BOOZTD 3
23:47:35 05/16/11
is that a busted valve guide?
CGDriven
00:35:55 05/17/11
Exactly....search my name..im known for working quick :) (n/m)
BOOZTD 3
00:54:56 05/17/11
and props on the hyper tear-down, damn! (n/m)
CGDriven
00:38:53 05/17/11
Jee-bus! You, my friend, are quick. ;-D
CoHPhasor
14:15:02 05/17/11
The disassembly was easy....
BOOZTD 3
15:38:47 05/17/11
